Achille Pavlidis
Level dimension for composite slabs
It is time for AC to provide a level dimension tool that can display elevation values for slabs made of complex profiles.
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
5 Replies 5
Hey Achille,
You didn't attach a poll to your post. Nevertheless, I think this is a good wish, in construction documents we many times have to display these two values. I would say that this level dimension should work to be able to display both the top and bottom of both the whole structure of only the core, and it should work for Slabs, Roofs and Shells since any of these three could be used to model composite slabs.
Achille Pavlidis
There you go Laszlo: http://archicad-talk.graphisoft.com/viewtopic.php?t=46720
With your remarks incorporated!
James B
Of note, the Dimension Label (Label tool) when attached to a Slab (or any element) can provide lots of information about the element it's attached to, including Top/Base elevation.
James Badcock
Achille, I voted essential.
James, yes, that Label is a start but it is not the full solution to this case. For example it does not have the Level Elevation marker, and also it can display the top and bottom of the full structure only, but not the top or bottom of the core. I can imagine that this Label could be made smart enough to do all those things, including the Marker when labeling Slabs, Roofs, Shells etc.
Achille Pavlidis
and if I may add, we need the + sign to always appear for the values greater than 0.
But still, I dont know if this will be satisfactory, because in large projects we need to place level dimensions on various points of the floor plan, not just once.
