Levels issue
Hi there,
A newby question im afraid.
I have a universal beam as part of my floor construction. On top of that a stud wall and another beam over that. How do I avoid seeing the beam that sits below the wall. Ive tried setting the cut plan half way up the wall height but otherwise lost.
Many thanks.
Lukle
10 Replies 10
lukle wrote:
The Universal beam I have currently frames a four sided room. If i want
to strech one side out the only way I seem to be able to do it so that the
joins at the corners are maintained is to make the who square ( 4 beams) into an object. Is there any way of streching out one side so that the other two beams strech with it, without turning it into an object?
Thanks again.
Lukle.
It is not possible to "stretch" objects. However if you use a profile through the beam tool, you will be able to do what you want.
