Bruce
Library Loading Report
In AC9 the library loading report dialog had these really handy buttons down the bottom labelled Copy, Print, Save As, Library Manager and Close. It also had a horizontal scroll bar and I could resize the dialog so I could read those long references.
What's happened to them in AC10? How do I get them back?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
13 Replies 13
Link
They are still there Bruce, but there is a bug which makes them disappear, along with the scrollbar on the side and the grab handle in the bottom right corner. Are those things missing too?
I don't know what causes it, but have noticed it happen after working on bigger projects for longer periods. Usually a restart brings them back.
Link.
Bruce
Yep, everything is missing - and they have never been there in AC10.
I will try installing the latest patch to see if that fixes anything. Cheers
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
Nope, no good. Still AWOL
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Link
Maybe it's a preference setting?
It's a far reach, but you could try temporarily moving your ArchiCAD 10 Basic.prf out of C:\Documents and Settings\<username>\Application Data\Graphisoft\ArchiCAD 10.0.0 INT R1 and restarting ArchiCAD.
See if that brings it back. If not put the prf file back.
Link.
Bruce
Ta, but no cigar
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
SeaGeoff
Ace
I see this frequently but can't figure out a pattern. Please post a screen shot here and report it as a bug with a reference to this topic.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Bruce
Screenshot as requested - how do I report it as a bug?
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Djordje
Start the Bug report manually, type in what your problem is, send it. Email your local tech support/GS Australia with the description, the bug report number, and the links to the posts here that describe the same behaviour.
Then, be patient ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Bruce
OK - how do I start bug reporter manually?
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
