2005-10-25 11:49 PM
2005-10-26 09:26 AM
2005-10-26 04:03 PM
2005-10-26 04:09 PM
roncbr900 wrote:No.
Thanks, but you missed what I'm trying NOT to do. I draw in HAIRLINE most of the time so I need a line that is very wide or thick while in HAIRLINE not TRUE WEIGHT.
AutoCAD allowed for Poly Lines to be modified such as width. Can lines or Poly Lines in ArchiCAD be modified WITHOUT doing it by pen weight?
2005-10-26 09:49 PM
2005-10-26 10:16 PM
Weston wrote:or . . . define a new linetype using many thinner lines that are very close together. ensuring the 'gap' value is set to zero will result in a solid line, but you can also create similar dashed lines as can be seen in green in the attached screenshot . . .
workaround; if you must...
use a wall with solid fill of the same pen color as the outline, and use the centerline drawing method to place the reference line at the center of the wall. use the wall thickness to control the width of the line.
not clear why you would want to draw the way you describe though...crisp,
2005-10-26 10:33 PM
