As Richard has indicated, cut planes are likely to be your issue assuming the wall is at the right elevation for what you want to show. As a crude guide...
A wall completely below the cut plane will show in outline only
A wall intersecting the cut plane will have fills
A wall above but falling within the cut plane range will be shown as overhead
I have found cut planes to be quite entertaining as you chase around adjusting their range settings and altering element display settings to make sure they show what you want.
