SergDryg
MEP incorrect behavior of the Cable Tray Routing tool
I noticed errors in the behavior of the tool in the cable tray path:
1. It is not possible to rotate the cable tray path.
2. When lifting vertically, the tray track is incorrectly shifted, it should be the same as when the track is horizontally shifted.
Recorded a detailed video. The video is also available at the link:
https://1drv.ms/v/c/64b3152aacaf33ba/IQB2GsYipTR3SL8sF3T3mdNFATKpAttW152pul5Pq6m2dqs?e=FjdDRI
В трассе кабельных лотков заметил ошибки в поведении инструмента:
1. Невозможно вращать трассу кабельного лотка.
2. При вертикальном подъеме некорректно смещается трасса лотка, должно быть также как и при горизонтальном смещении трассы.
Записал подробное видео. Также видео доступно по ссылке:
Operating system used: Windows 25H2
1 Solution
Claudiu Serban
1. I've been spaming this bug each beta since ... AC27 i think. Its still not fixed. It only happens to single segment vertical routes.
2. This happens with all route types. Archicad favors elements placed horizontally, even tho that's not always the case. It's been like this for ages. Is it ok? Of course not. Just another **beep**up from the AC team. At this point i guess people stopped wondering who oversees the development and asking for fixes.
Its the new industry standard. You get less features, more bugs, BUT SUBSCRIPTION AND AI.
Hurray
Archicad 28/29, macOS 26
Go to post
3 Replies 3
Claudiu Serban
Hurray
SergDryg
Hi...
Unfortunately, the 29.1.0 RUS 4006 update does not solve the problem.
https://1drv.ms/v/c/64b3152aacaf33ba/IQDAkANqbU1RRY14_HYEKhIZATSfbCqC4LG4PqfPRFcf3KU?e=Ow5oqh6.mp4
SergDryg
Unfortunately, there is no solution yet.
