2023-10-02 05:17 PM
2023-11-02 03:34 PM
Hi @Camu
5. Could you elaborate on this a bit? I understood that we are talking about the representation in 2D of a pipe route element and the differences between how the horizontal and the vertical segments look, but I'm not sure I correctly understand the issue. If you can add some screenshots about the thing you are experiencing and how do you think it should be, even better.
6. Please attach a file showing this issue, so we can investigate this issue.
Thanks!
2023-11-06 07:57 AM
As we can see in the image; the detour is on the ground floor( blue pipe and same for the red). If my route crosses the first and second floors, the representation of the elbows is transferred to these 2 floors; what is needed at the execution plan level. I therefore had to separate the paths by floor to avoid this inconvenience.
For the MEP in red I would like the plan symbol to be displayed as a dotted line because it is a view of the ceiling and again it is no longer possible with this new version of MEP
2023-12-15 10:20 AM
when do you plan to release a fix for this MEP?
2024-02-13 08:49 AM
Any information about MEP correction ???
2024-02-13 08:56 AM
The latest update for 27 has been released as a preview.
Give it a try if it is for your region.
