Llian
MERGE TWO FILLS
There must be a way...likely I forgot..how do you merge two fills into one?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
6 Replies 6
RandyC
pet pallet - add to polygon - look for a + sign --
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Llian
Thanks Randy. I am aware of adding [+] to the polygon but I am thinking if I can select two intesecting polygon and merge them.....
Eduardo Rolon
Edit->Reshape->Fill Consolidation
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Llian
WOW......Thanks so much!
Good day.
Whenever I try to merge two fills with the Fill Consolidation tool, whether from the toolbar, keyboard shortcut or edit menu, nothing happens.
If I'm not mistaken a wizard window is supposed to pop up that lets you tick boxes of every Line Consolidation option that you wish to execute.
The fills I'm trying to consolidate are identical and I've made sure that they don't have transparent backgrounds.
What am I doing wrong?
Regards Z.
It is working for me.
