Making Oval Handrail ?
Would rather not spend time tweeking the stair maker tool as it hasn't been that productive in the past.
any hints on how to model a handrail for an oval stair, as shown attachement?
Perhaps a 2D profile applied to a primitive form?
Will appreciate any ideas/suggestions.
Thanks,
Cedric Araica
36 REPLIES 36
I have modified a tube of mine. This one allows to follow an elliptical path.
Parametric, four profiles,
X and Y radii, start & end rotation angles, slope or height, by graphical hotspots.
Additional text for height. AC 8.1 & 9
Enjoy.
Attachment moved here by the author
Hello Olivier,
Nice work !!
I was playing around with your handrail object and tried making
a rectangular handrail 2" wide and 36" high because I wanted
to see how you handled the issue I brought up in a previous
post on this topic.
To quote myself:
"I tried to make such an object using the TUBE command but
TUBE tilts the corners of the facets of the arc to the angle
defined by the incremental elevation change along the path.
This plays havoc with the object when an elliptical shape
is generated and even when the shape is a circular arc
there is distortion caused by this tilting. "
When I viewed your object in 3D as a TUBE it had the same
problem as described above but if I switch to TUBEA the corners of
the facets are now vertical and the distortion goes away.
This is terrific !!!
I have never studied the TUBEA command (my error)
but now I will thanks to your demonstration of it.
Thank you Olivier.
Peter Devlin
Nice Work Colleague
My Congratulations
Djordje
Gurus ...
Please post your object here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=6864
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Peter wrote:
John,
Take a look at the attached object and you will see what I mean.
Thank you,
Peter Devlin
Peter I downloaded your rail and am busy using it to make a sloping curved multi pipe horizontal railing on a ramp. It is great
Thanks Greg.
Hello Greg,
I would definitely recommend you use Olivier's object
as you have a choice of using the TUBE command
or the TUBEA command. This can solve some problems
that I had pointed out on this thread.
Peter Devlin
Peter wrote:
Hello Greg, I would definitely recommend you use Olivier's object... Peter Devlin
Thank you Peter, will do.
Greg.
