2008-11-21 04:16 AM
2008-11-21 04:39 AM
2008-11-21 04:49 AM
2008-11-22 06:37 PM
2008-11-24 08:42 PM
2008-11-25 12:14 AM
2008-11-25 12:35 AM
fabricfo wrote:This is a function of the 3D Document, not the 3D Window. Create a 3D Document of the 3D Window, then edit it's settings similar to the image below.
I used the 3d view to generate my site plan. But the shadows doesn't appear (only their outline) and the cover fills of the mesh and the roads either..
What I'm a doing wrong??
fabricfo wrote:You'll need to assign a cover fill to the roof to mask anything below it. Even if it's a blank white fill. Then bring the roof to the front of the Display Order.
Creating a new model view i turn on all the layers that i wanna show...
but the stair and the cars aren't on their heights.. the stairs is to show on the home store and one above... so I don't know why is showing through the roof
2008-11-25 04:20 AM
2008-11-25 05:36 AM
fabricfo wrote:Cover Fills won't come through from the 3D Window.
How did you do to make a site plan showing the cover fills in a 2d mode without using the 3d projection?
2008-11-25 01:46 PM
