Making a Site Plan
I'm trying to make a site plan of my projects in Archicad
But I couldn't figure it out how is the best way.
is there a view that shows the projection of all model??
using the projected of the stories I couldn't do it
How did you do it??
15 Replies 15
fabricfo wrote:
...There are no way to make a site plan without using the 3d document... But if I use the 3d view to generate que plan, the trees object will come as there 3d representating, insted of the desired 2d representetion of them that i use in plan ...
Do it the old way! Draw the 2d site plan as normal and bring in the shadows as fills separately.
To create the shadows set up a 'top' view using the Axonometry/parallel projection. View it using the Internal engine with shadows (no contours).
Select the area in the 3d window using the marquee tool. If you now Ctrl+C to copy the image, a pop-up box will appear where you can specify what parts you want copying. Select 'Scaled Drawing', 'None' for construction elements, and 'polygons' for shadows.
Go to the floorplan and paste. Do an undo and redo to select them for editing.
Group them, then change them all to 25% transparent, dark grey foreground, transparent background (Or whatever works for you). Use 'display order' to bring them to the front.
It is best to leave the shadows until last as they don't update if you add further geometry, but thankfully it is a relatively quick process to bring in new shadows if necessary.
Hope that helps!
Djordje
... or anything else that you have to see.
The trick to efficiently using ArchiCAD is to think "around the corner". Linear thinking only makes you say "It cannot be done". It can. You can. Only you don't know it yet.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
How is the result?
I have a friend asking that whether AC can make a site plan or not, because he is working in urban renewal authority, he don't have make so detailed building but a large site plan.
besides, in AC the component is mainly for building, especially architect, not for a city, how do you use the components as road, bridge, railway..... anything that is infrastructure ??
And also if we can find the component to express something by something, for example, we use slab as road.... but some intelligence is missing.... my friend want to build a road much more easier, just like Simcity. (because I told him that AC is not really like the traditional 2D/3D CAD, just like The Sims. )
Here is a Hong Kong Photo, and you may google more if you need more information about Hong Kong.
Dwight
Your Friend probably wants SketchUp.
Here is what SketchUp does linked to Google Earth. And this is just a rudimentary database unlike the commercial Urban GIS services.
You see they have bridges and even a Stat-chew tool [Statue of Liberty finally in the model!!]
Dwight Atkinson
Dwight, he is using sketchup right now . .... but he is wondering any BIM could help his industry in the future.
i surely recommend AC to him, but it may not suit him...........
Dwight
It is all about the end use and how much accuracy is needed. I am not thinking that Archicad is really set up to make sweeping roadways.
At least it is easy for him to find out with the demo.
Dwight Atkinson
