Marqueed 3D window Select All selects elements outside?
Just starting with AC 9, US: I use the marquee to select a chunk of the model, look at it in the 3D window, click on the Window tool, do Cmd-A for Select All, and together with the six windows inside the marqueed/shown chunk of the model I also get highlighted selection dots for the ghosts of all the windows in the same story, *totally outside the marquee* (and they are also counted as 'Selected:' in the Find & Select window).
This is very scary, and it did not happen in 8. Is there any Preference or something that will avoid it?
2 Replies 2
I just verified the behavior. This is a serious bug! I'll report it right now.
Djordje
Don't have AC installed at all, but from flaky memory: there IS a setting whether you will cut the elements with marquee or not. Maybe that is the problem?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
