clauds1223
Masking Regions
Hi there,
I would like to know how to subtract the internal fill from the external fill please, so you're just left with the blue area as a fill.
Kind regards,
3 Replies 3
CosminF
Select your fill, select the fill tool and draw inside your big one. And it will substract a hole.
And to substract an existing fill/ shape, you can use the magic wand (default shortcut: spacebar) to select it.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Lingwisyer
Guru
I suggest you turn on Tool Tips and have a quick look at the different pet pallette options you have for the different tools as you come across them. With all of the basic questions, you will probably save a bit of time over waiting for a reply each time.
Ling.
Ricardo Lopez
Hi @clauds1223
This trick works for slabs, fills, etc. (Watch the attached video) ▶️
Once the fill is drawn:
  1. Select it
  2. Select the fill tool.
  3. Draw the inside region.
  4. The hole is done.
Ricardo López, M. Arch.
