Maybe an easy problem???
Hello.
According to attach picture I have a problem with ---.---. Lines that shows the walls etc on the second floor. This makes the drawing confused. How do I do in order to not see these lines on the first floor?
/Henrik
AC12
3 Replies 3
Djordje
Are your walls protruding through the slab? Looks like they are, and that they are on projected with overhead ...
Check the 3D - either the storey settings or the wall heights are wrong.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
You can also check which Story is set to Home Story, and whether the Wall is set to be shown on Home Story only or All Relevant Stories.
check the Floor plan Cut plan setting. If there is setting show down to: then Current Story 0 it could hapens how it presented on your exsample.
