MrSoleil
Mesh points only from poly lines / lines?
Is there a way to create a mesh with points only (no lines/ridges) from a survey (lines, poly lines)?
Mesh lines don't work for modifying the terrain later on.
Please don't tell me Archicad only has manual input of those...
4 Replies 4
Hello MrSoleil,
To import a survey you have to clic on Files/Interoperability/import survey data (or something like that I'm french).
Mesh lines works for modifying the terrain later on too !
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Ricardo Lopez
Hi @MrSoleil
As @Christophe Fortineau mentioned, you can import surveyor's XYZ points under File> Interoperability> Place Mesh from Surveyor's Data.
If you don't want to see the edges/ridges or points in your Floor Plan and Section or 3D views you can choose the Show User Defined Ridges and All Ridges Selection under Mesh Selection Settings for a cleaner look. Sometimes even changing or disabling the Cover Fills helps to achieve this.
Ricardo López, M. Arch.
MrSoleil
I mean to create points, not mesh lines. The lines are impossible to work with, modifications are incredibly difficult. Points can be deleted. Is there really not a way to get points instead of lines? Shouldn't be that hard for archicad.
AllanP
if you have a mesh, and you select the mesh, and have the geometry Method set to Polygonal
then just double click at a point on the mesh, it produces a point, not a line.
click "OK", then you have your point(or hit the enter key)
repeat for all points...
i know its a bit slow, but it gives you points from 2D data.
I don't know if this helps.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
