anto_bg
Mesh tool question
Hello ArchiCad users,
I have a question regarding the Mesh tool which I haven't used in a while and I have forgotten now to smooth the edges of this "cake". "All ridges smooth" doesn't do anything in this case. I am using AC25 on Win 64.
1 Solution
Are you sure that is an actual mesh?
Meshes can not have vertical surfaces except for the very perimeter of the mesh..
If it is indeed a single mesh, you would have to delete the contour at the bottom of each step.
Edit:
Lingwisyer's comment has made me think this is a series of stacked meshes.
Then you would have to transfer the contours of all of the upper meshes to the lowest one and then elevate each contour.
Go to post
2 Replies 2
Edit:
Lingwisyer
Guru
You have not created a new mesh for each contour have you... instead of adding new nodes to and existing mesh?
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
