2024-10-24
03:09 PM
2024-10-29
08:50 PM
Hello ArchiCad users,
I have a question regarding the Mesh tool which I haven't used in a while and I have forgotten now to smooth the edges of this "cake". "All ridges smooth" doesn't do anything in this case. I am using AC25 on Win 64.
Solved! Go to Solution.
2024-10-25 02:32 AM - edited 2024-10-25 03:32 AM
Are you sure that is an actual mesh?
Meshes can not have vertical surfaces except for the very perimeter of the mesh..
If it is indeed a single mesh, you would have to delete the contour at the bottom of each step.
Edit:
Lingwisyer's comment has made me think this is a series of stacked meshes.
Then you would have to transfer the contours of all of the upper meshes to the lowest one and then elevate each contour.
Edit:
2024-10-25 03:20 AM - edited 2024-10-25 03:21 AM
You have not created a new mesh for each contour have you... instead of adding new nodes to and existing mesh?
