2010-02-10
02:06 AM
2023-05-24
08:00 PM
Rubia Torres
2010-02-10 04:28 PM
2010-02-11 04:35 PM
2010-02-11 04:48 PM
2010-02-11 05:30 PM
2010-02-11 06:12 PM
R wrote:I have no problems with much larger and much steeper sites - going back to version 7.
I am trying to understand some of the parameters that lead to greater accuracy. I am modeling a 10+acre hillside site, with vertical elevations of more than 70', and I have a survey with 1' contour lines. If I put all that into the model everything slows to a crawl, and I can't show anything live in 3D.
2010-02-11 06:12 PM
2010-02-12 03:21 AM
2010-02-12 03:33 AM
2010-02-12 03:48 PM
R wrote:This does not sound like a result of rounding errors or the accuracy/detail of the site model but more like either a procedural issue or a bug in the calculations. You should be able to check this by scheduling the volumes of the various site meshes and checking them against some thumbnail arithmetic.
I do this kind of site design a lot, but this is the first project where I have used ArchiCAD to directly calculate volumes of cut and fill. Much to my chagrin my results seem to be not valid. I say that cut and fill balance, while my consultant says there is twice as much cut as fill. We are not even close in our quantities. This is embarrassing!
