Missing Control Box and Coordinates box
I use these boxes all the time, but no matter if i go into the pallete select menu to turn them on the screen flickers a little but they never appear
no problem using other palletes, just these 2, and only in this machine
its been doing it for a while now and is quite frustrating.
sorry this is in AC 11 also
David Maudlin
methy:
They may have ended up off screen. You might try a different Palette Scheme in the Work Environment, or changing your screen resolution, to see where they are. Some forum members that use Vista may have some other ideas.
HTH,
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
