2024 Technology Preview Program
Model View Options - Override Fill Display
Ahmed_K
i'm working with composites , i want to plot the plan in a smal scale , so i want to override the composite walls with a simple filled wall
the is no options in the MVO to override a composite with a simple fill wall .
any suggestions please ??
Archicad 27
Windows 11 professional
Erwin Edel
You can override Cut Fills to have a solid foreground in MVO and untick Show Skin Separator Lines.
If instead you want a specific vectorial fill for al Cut Fills, you would have to fiddle around with renovation filter options and Renovation Override Styles Settings.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
If you use the solid foreground option (it is either that or empty) you can set up and alternate pen set so that you can have a black or grey fill (or whatever colour you want).
Ahmed_K
Thank you guys !! Graphisoft shoud make it possible to override composites with simple fills instead of solid background
Archicad 27
