2019-08-20
05:46 PM
2023-05-24
07:21 PM
Rubia Torres
2019-08-21 03:17 AM
2019-08-21 02:33 PM
2019-08-21 03:13 PM
2019-08-22 05:32 PM
Lingwisyer wrote:Thanks for your respond, side elevation has a curve
What is the side elevation like? Does it curve outwards? What is the front elevation like? Does is splay outwards?
Ling.
2019-08-22 05:33 PM
ejrolon wrote:Yes, you are right, with the help of your replies and a colleague of mine at office, I managed to do it
With the amount of info given a Shell looks like the correct tool.
2019-08-22 05:34 PM
Erwin wrote:Thanks a lot, It worked
Might need to split it in half down the middle and use two shells, but I think it will work best as well. Use the 'ruled' shell, method 'detailed' and you can define both curved edges and it should fill in the rest.
2019-08-22 05:36 PM
