Modeling Question
Hey ArchiCAD folks,
I need your help to model this shade, I tried the morph but didn't work.
Appreciate,
ArchiCAD 22
Windows 10
Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.2GHz
Ram:32 GB
7 REPLIES 7
Guru
What is the side elevation like? Does it curve outwards? What is the front elevation like? Does is splay outwards?
Ling.
Eduardo Rolon
With the amount of info given a Shell looks like the correct tool.
Eduardo RolĂłn AIA NCARB
AC28 US/INT -> AC08
another Moderator
Erwin Edel
Might need to split it in half down the middle and use two shells, but I think it will work best as well. Use the 'ruled' shell, method 'detailed' and you can define both curved edges and it should fill in the rest.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Ling.
Thanks for your respond, side elevation has a curve
It's a 2 different profiles that are on a curved path
Yes, you are right, with the help of your replies and a colleague of mine at office, I managed to do it
Thanks a lot, It worked
I started with the morph, which helped in creating the shell, I split it into 3 parts.
