Modeling Question
Hey ArchiCAD folks,
I need your help to model this shade, I tried the morph but didn't work.
Appreciate,
ArchiCAD 22
Windows 10
Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.2GHz
Ram:32 GB
7 REPLIES 7
Lingwisyer
Guru
What is the side elevation like? Does it curve outwards? What is the front elevation like? Does is splay outwards?
Ling.
Eduardo Rolon
With the amount of info given a Shell looks like the correct tool.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Erwin Edel
Might need to split it in half down the middle and use two shells, but I think it will work best as well. Use the 'ruled' shell, method 'detailed' and you can define both curved edges and it should fill in the rest.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Ling.
Thanks for your respond, side elevation has a curve
It's a 2 different profiles that are on a curved path
Yes, you are right, with the help of your replies and a colleague of mine at office, I managed to do it
Thanks a lot, It worked
I started with the morph, which helped in creating the shell, I split it into 3 parts.
