2008-10-28 01:41 PM - last edited on 2023-05-23 03:07 PM by Rubia Torres
2008-10-28 03:51 PM
2008-10-28 04:13 PM
2008-10-28 04:55 PM
2008-10-28 05:41 PM
malte wrote:Yes, complex profile and beam tool is the way to go for coping stones. You may notice that both ends of a beam remain vertical regardless of the sloping angle which may not be correct. Another SEO can be used to square off the end if necessary, but it can get a bit messy.
...The wall does actually have a coping stone running along the top which I could model using complex profile and the beam tool? I would then duplicate the coping and put one on a special layer - operator layer. Again hidden on all output formats. Would you put all your operator elements in the model on the same layer. So on a 'operator layer'?..
2008-10-28 07:39 PM
malte wrote:Operator elements only need to be hidden when you don't want to see them. In this case, just do the SEO and then let them be.
Thanks for the quick reply. The wall does actually have a coping stone running along the top which I could model using complex profile and the beam tool? I would then duplicate the coping and put one on a special layer - operator layer. Again hidden on all output formats. Would you put all your operator elements in the model on the same layer. So on a 'operator layer'?
