Lingwisyer
Guru
Module Overlap
Hi all,
Issue: Walls are clipping in their entirety instead of just where the walls overlap.
Situation: I have a series of rooms that have been modelled as a repetitive module along a curve resulting in a varying overlap. In order to compensate for these shifts I have modelled the overlapping walls with different Intersection Priorities. Originally this has worked fine with the higher priority wall clipping the lower one where it overlaps. Since then the overlapping walls now contain multiple sections due to the material difference between the interior and exterior walls. Now, when one of the higher priority walls falls entirely within a low priority wall it clips the entire wall instead of just where it overlaps...
Thanks,
Ling.
ps. Slightly different but related issue: When the reference line does not overlap, the wall does not clip...
0 Replies 0
