ā2013-04-11
04:06 AM
ā2023-05-24
07:29 PM
Rubia Torres
ā2013-04-11 05:42 AM
ā2013-04-11 01:50 PM
blimp wrote:Morphs created in Elevation are on the plane of the Elevation Marker (cut plane).
Now is there a way to choose that plane in elevation or a plan view..?
ā2013-04-11 02:01 PM
ā2013-04-12 09:50 AM
ā2013-04-12 10:01 AM
ā2013-04-12 10:06 AM
blimp wrote:That's correct. You can draw temporary sections or elevations (doesn't matter which) and you can move them around as needed or just delete them when you no longer need them.
So basically what I'll do is simply draw a "section" closer to the wall or slab I plan to draw a morph on, then simply open that section, draw the morph shape, switch over to 3D and extend the morph.
ā2013-04-12 10:16 AM
ā2013-04-12 10:19 AM
ā2013-04-12 10:26 AM
