Morph_stairs with radius chamfer..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-03-30
04:31 PM
‎2023-05-24
07:21 PM
Rubia Torres
Any idea WHY THE CHAMFER tool is not allowing me to select the lines in their totality in order to apply the chamfer radius? See photos.
Its the bottom line thats more of the problem. Top horizontal line has smoothed. Bottom however only works at one end of the stair -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-03-30 07:17 PM
Did you try to draw a plan with morph tool before to pull it ?
Like a complex profile about wall, column or beam but directly with morph tool.
You are able to smooth your morph by this way :
Draw / Modify Morph / ... (there is a tool like Smooth but I can tell you cause I use a french archicad
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-03-30 07:42 PM
I did this on the attached image and you can see the result on the Morph at the front.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-03-30 08:50 PM
I understand the principal but not sure how do delete the curve portion or any other portion for that matter without just deleiting the whole stair/morph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-03-30 08:51 PM
pas soucis....
merci d'avance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-03-30 09:17 PM
fyi, The top line I could do, its the bottom one where it deosnt seem to like it.
The chamfer doesn't apply to the ccomplete line at the bottom but only the edges of that line.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-03-31 03:07 PM
see attachment..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-01 12:40 PM
Hope that helps.
