Multi Level Stairs
How can I create a stair that continues for multiple levels?
7 REPLIES 7
NCornia
Graphisoft Alumni
Graphisoft Alumni
All of the stair objects can be adjusted for height, so you can make them as tall as you want. The only thing is that if the stair is a U or L shaped stair they are only going to retain the 2 runs. Could make for a steep climb.
If you want a u-shaped stair to run multiple stories you will need to place the stair on each story with a landing at each level for one stair to end on and the other to begin.
Download the ArchiCAD Essentials interactive training guide :http://www.graphisoft.com/education/training_guides/
Chapter 4 Make stairs - http://www.youtube.com/watch?v=Myq4wei673g&feature=related
Chapter 5 Make openings for stairs - http://www.youtube.com/watch?v=bwHmCNVkDmI
You can also make your own stairs using slabs, complex walls and so on.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
We were able to create a stair tower with a series of of stairs that extend vertically through the shaft. While each flight of the stair is a separate object, the inside guard/handrail is a single object the extents the full height of the stair.
(It took a series adjustments to get the tread offsets as desired.)
Regards,
Joe A.
(since 8.0)
Well.. Revit does.
True.
And ARCHICAD's Stair Tool does dozens of things Revit's Stair cannot.
LaszloNagy wrote:
True.
Such as causing the user to have a mental breakdown..
theotheranony wrote:
LaszloNagy wrote:
True.
Then why not use Revit?
Why use a software that you feel gives you mental breakdowns only to complain about it?
I can't imagine myself over at Revit forums complaining about how difficult and complicated it is to use, when I can just......NOT use it at all and save myself the headaches.
chrrev
LaszloNagy wrote:
True.
I am facing this problem with the stair tool, it is a real shortcoming and I can see no reason why it could not be fixed.
Typical lower storeys in mixed-use developments have ground floors of anything between 6 to 8m and perhaps 3 or 4 levels above that which necessitate more than 2 flights...
Why on earth can't I just continue the stair past 2 flights is mind boggling...
I am definitely not interested in making comparisons with other softwares, but this is really lousy I have to say. Especially in light of the fact that the first post is dated 2011 and here we are 8 years later.
That does not take away anything from the fact Archicad is a great software, but the whole point of these forums is precisely to try and improve the product. I think it is a very poor approach to dismiss genuine issues with a silly statement that Archicad stair tool can do things Revit can't. We should not get to that level, it is useless.
