‎2014-09-10
11:00 AM
‎2023-05-24
12:43 PM
Rubia Torres
‎2014-09-10 07:47 PM
Is there a way I can manually lock the walls to the third floor but keep their baseline bellow the third floor line? Or Is there any other way I can solve this?Yes, try this:
‎2014-09-10 08:05 PM
NandoMogollon wrote:The poster is only using AC16.
Yes, try this:Hope it helps
- 1. Select the walls in the dropped slabs
2. Go to the settings (Ctr+T / Cmnd+T)
3. Set the Home story and Wall top to the desired Levels AND set the Offset needed.
4. Now make sure the walls are showing in Floor plan to "Floor Plan Range"
5. Voila, they should appear properly in your plans
‎2014-09-10 09:25 PM
gpowless wrote:Yep, correct.
‎2014-09-10 09:46 PM
