Have you tried re-applying the standard Work Environment?
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
I could not find a way to turn it off. With the Arrow Tool selected, can you change the Quick Select option (Magnet icon) in the Info Box?
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual ⢠Mac mini M4 Pro OSX15 | 64 gb ram ⢠MacBook Pro M3 Pro OSX14 | 36 gb ram
I tried applying the ArchiCAD 17 Standard and the space bar would not turn off the magnet. If I click on the magnet in the tool bar I can turn it on & off, but, it was so easy when my space bar would do it. Thank you.
Quick Select is a non-customisable shortcut so it shouldn't be possible to deactivate it.
The only thing I can think of is you have another program running in the background that is 'hi-jacking' the space bar shortcut.
Good idea to check! The space bar does not work the magic wand either. Space bar works normally when I'm typing. There are no other programs running.
Thanks.
This is a long shot, but could you assign the "spacebar" to another shortcut by mistake?
Robert J. Garand ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
The space bar is not used as a shortcut so there is no way it could have been assigned to a different command. I wish I knew what the problem is & how to solve it.
