2007-07-19 12:51 AM
2007-09-01 04:00 PM
Don wrote:The only time I think AC11 runs slower than AC10 is if the Trace Reference uses difference layers than the foreground working view. It is slower, but it's tolerable. It's also something that I only use for a few minutes at a time.
I updated AC11 and tried it again today, based on your post. You say that you have many stock G5s running AC11 with no problems. To restate, AC11 runs without major glitches (so far) but to me is irritatingly slow on the 2d redraw.
If I think of it, I guess it is acceptable, but really any amount of delay is a big pain. I guess it's worth the trade off, but it seems to me things should get faster not slower.
Do you not experience any slowing at all? And have you done any adjustments to compensate
2007-09-08 07:39 PM
TomWaltz wrote:Thanks Tom,
To be blunt.... this is such a load of crap it's unbelievable.
I have 50 (five-oh, fifty, funfzig) stock Dual 1.8 or 2.0 GHz G5's running Archicad 11 on OS 10.4 without any problems. I also have 15 Intel machines, also stock, running without any problems. Projects range from 4000 to 300,000 SF. People run Archicad, Thunderbird, Firefox, iTunes, iCal, and sometimes even CS2 (or CS3, depending on whether they are on the G5 or the Intel) all at the same time.
Nothing custom, nothing special, and above all, no fear mongering involved.
I'm grateful for the slow response because it slows the spread of such bull-oney.
2007-09-08 09:37 PM
2007-09-10 06:09 PM
Dwight wrote:Hi Dwight,
Even though this exchange appears to be sword play, thank you for such a wonderful essay.
It has given me good reason to consider drive partitioning again, since over the years I've just kept adding drives to the system rather than considering a more finely-tuned approach.
2007-09-10 06:36 PM
Jeffrey wrote:Jeffrey,
The OS is altering and or destroying data and devices as it appears unable to protect against reentrant or concurrent access to resources. Function calls are not being serialized properly rendering work loops and events incapable of performing their functions and/or accessing critical resources across four architectures of hardware. (G4-IC2D). It appears that the algorithms are correct (to my limited knowledge) and these errors would not be caught by any debugging method or software intended for such use. Whenever dependencies are on time calculations applications crash, hang and/or data is lost and hardware failures occur as the time formats being used are not able to properly sync as many of the applications are using too many time formats that are not being properly transfered and are instead being transposed.Seconds are calculated as minutes, decimal seconds as seconds and so on depending on the specific application and the time formatter it uses locally and/or internally.
2007-09-12 06:15 AM
Dwight wrote:Yes... watching the WCT webcast while running Archicad works much better now
Dual processors and an excess of RAM let you keep more tasks running without slowdown.
2007-09-25 04:32 PM
Ralph wrote:It is an esoteric topic about the imminent end of support for a particular platform/processor and it's current lack of performance. together with the original poster's return to an older version of an application (AC) and other backwards compatibility concern that has been addressed in this thread as well. I gave a solution that works in either direction providing the only reasonable explanation of why performance has taken a hit and numerous updates and patches have failed to fix. What is yours?
Jeffrey,
I'm still not sure what this posting is about - it certainly doesn't seem to relate to the topic.
Ralph wrote:No I am identifying a single problem and recounting how it can conceivably be the be the cause of any or every problem a computer can have including performance or the lack thereof. I also have a machine that runs multiple OS's where I can see the differences and the most concerning are the HW differences. Go to Apple's ADC site and enter "Keep Out" in the search field.
You seem to have recounted almost every conceivable problem a computer can have and blamed it on the OS.
Ralph wrote:It's been a long pause. This coming Dec. will be three years. It took about a year to identify the error. Your machines suffer the same ills you just don't have the same symptoms or they have not been intrusive enough for you to care or it is something you would consider "acceptable". I can reinstall a new OS on my machine in about 2± hours depending on the type of install and have done so numerous times every conceivable configuration. I have had numerous pieces of hardware replaced, Replaced two G4s with two new MacIntels that displayed many of the same symptoms as the two G4's that they replaced and even worse. My MBP1,1 was replaced with a MBP 2,2 and the other was recently replaced (finally after numerous HW replacements) with the latest MBP and immediately sold as it displayed the same and the person who owns it has had enough and as purchased another G4 so that they can actually do what they need to do. They use Apple's Pro tools.
If you pause to think about it, doesn't it seem more plausible that something is simply wrong with your hardware or installation?
Ralph wrote:It depends on which definition of argue you are using. I am citing evidence in support of what I am saying. You are not. Can you cite anything supporting your position. I am providing a reasonable explanation of how and why and if you actually read the bug header information you can see I am identifying that an issue is indeed in the kernel. The quote that you posted was not a "complaint" to this forum but part of a bug report that had been disregarded until legal dept. became involved and if you look at your time-stamps and the limited information available on Apple's updated and security patches you will see the evidence that they are finally tracking the issue down.
]The primary responsibility for the allocation and management of resources and concurrent processes rests with the kernel, in this case XNU, a Unix hybrid of FreeBSD kernel with a Mach 3.0 microkernel. No one can argue that a given operating system is perfect, and debates rage amongst experts as to which approach to the OS kernel is the best, but you can't seriously argue that the Mac OS foundations are fundamentally flawed. Security experts (and the competition) would be having a field day roasting Apple if this was the case.
Ralph wrote:Bugs are well understood? What evidence supports this? Well I really want to find this documentation and can assure that no you cannot find out about the details of the fixes especially if they pertain to security issues and Information Assurance would not even be acknowledged as an even remote possibility by any computer/SW manufacturer.
The underpinnings of the Mac OS are very mature and stable. Of course there are security and bug fixes, but the nature of these bugs are well understood. Many components in the Mac OS are open source (to which Apple contributes a great deal now) and of course these components are patched for refinements or bug fixes as required. You can find all the documentation for these fixes if you really want to - there is nothing ominous or underhanded about them.
Ralph wrote:
It might help if you simply list the specific symptoms of the problems you're having under a different topic and not jump to conclusions about the cause. One of my Powerbooks suddenly began to randomly freeze or suffer kernel panics, but I conclusively tracked it down to a failed RAM chip, replaced the RAM, and all was well again (no software was reinstalled).
Ralph wrote:This isn't recommended anymore by who? For what reason? I give a reason. Even my externals are partitioned because of the fact that they do rely on a single head and I don't need it to wast time reading and writing something I am not going to use. I prefer a direct flight and avoid stops and layovers as much as possible because It is quicker.
Regarding partitioning of hard drives, this isn't really recommended any more. There is some debate, but there are no compelling gains to be made (on the Mac at least - Windows user might gain from it). I would only suggest partitioning if you intended to run multiple OS's on the same machine, but even that will run better with separate hard drives. Partitioning will only take time and eventually leave you wishing you'd left it intact. External hard drives are cheap, and will generally work faster than partitions (which depend on a single drive head).
Ralph wrote:I avoid many of Apples apps for this very reason. They don't organize anything according to how I use them and are often not too friendly with other apps. i.e. iPhoto. As for orginization, I don't care what the dates the images were created and don't want them re-organized accordingly as well I don't want/need a hierarchy of hundreds of empty folders to sort through when I need to access them in other apps., nor do I need excessive thumbnails for every image.
Backing up only documents is made easy by the way Apple organises files for you. I recommend sticking to their model - it really is very well thought-out. Don't attempt to move the VM swap file to another partition - get it wrong, and it will be a disaster.
Ralph wrote:Not surprising as you appaerntly have never used partitions and have not provided any advice whatsoever to the original post. In addition to lack of performance, the symptoms are that Mac OS has destroyed and or can't read files and discs it created. Applications crash too often, primarily Apple's. Safari crashed numerous times while trying to post a reply. PPC apps work the best on an intel Universal apps don't and a PB G4 on 10.3.8 outperforms a fully supported MBP. Hardware just doesn't work. Again painfully obvious on the G4 booting into different OS's.
All in all, I wonder if some of your recommendations haven't in fact caused some of the problems you are experiencing? Start a new thread, focus a bit more on the symptoms, and hopefully we can get to the bottom of it
2007-09-25 06:44 PM
Jeffrey wrote:I've been a registered member with ADC for many years now, so that makes it easy. Just give me a link to the article which best describes this problem and I'll look it up. Another link to an outside source substantiating the problem would help too. Then everyone can understand the issue.
I am identifying a single problem and recounting how it can conceivably be the be the cause of any or every problem a computer can have including performance or the lack thereof. Go to Apple's ADC site and enter "Keep Out" in the search field.
Jeffrey wrote:It seems you've had a bad run with the hardware. But most people don't, myself included. I push my hardware to the limits and performance matters to me, but Apple's kit has almost always been very solid.
Your machines suffer the same ills you just don't have the same symptoms or they have not been intrusive enough for you to care or it is something you would consider "acceptable". I have had numerous pieces of hardware replaced, Replaced two G4s with two new MacIntels that displayed many of the same symptoms as the two G4's that they replaced and even worse. etc.
Jeffrey wrote:My position is that I know of no evidence of a serious flaw in the Mac OS kernel. If you can provide links to qualified sources, I would change my mind.
Jeffrey wrote:This sounds like conspiracy theory - all the security experts, engineers, and manufacturers are all deceiving us, and don't really know their stuff? I don't buy it.
If security experts were such "experts" there would be no issues on any platform. [...] Maybe the engineers don't have a handle on floating point arithmetic or IEEE 754. Maybe all the HW manufacturers can no longer produce reliable equipment ...
Jeffrey wrote:Almost everyone posts details of bug fixes, including Apple. It's not a secret - all the security updates back to '05 are listed:
Jeffrey wrote:Sorry mate, you're on your own there. There are a heck of a lot of Apple 'power users' out there, and they wouldn't stand for the problems you describe. Apple is practically the standard for some industries - often very resource hungry, e.g. media, film, art, etc - and they like this kit because "it just works". BTW - I used to partition drives, maybe 15 years ago. External hard drives are easier, faster, and cheap.
2007-09-26 01:21 AM
2007-10-29 07:31 PM
Ralph wrote:So Ralph again what's your point? You suffer from narcissism? I have been a member for many years as well and it doesn't make me any smarter. One must read, comprehend and use the code for any of it to be worthwhile.
Ralph wrote:No. My hardware was fine until I installed 10.3.9 and QT 7 then my projects and hardware started to fail. The G4 running anything other than 10.3.9+ is fine and all my hardware works correctly. Before I discovered the nature of this error I replaced it with a MBP 1,1 and the issues were worse finally got it replaced with a 2,2 and the issues still prevail.
Ralph wrote:If I wanted to conjure up a conspiracy theory I would have asked if they finally "knifed the baby"
Ralph wrote:Almost everyone. APPLE DOES NOT. PERIOD-!! They won;t even provide details after the fix. I remind you that you missed that first paragraph and that this is not "fixed" apparently not even in Leopard.
http://docs.info.apple.com/article.html?artnum=61798
There is more detail about each specific update, e.g. for Security Update 2007-007:
http://docs.info.apple.com/article.html?artnum=306172
And within that, you there are links to bugs fixed in open source/3rd party projects, e.g. Kerberos, in this case credited to a security expert (they do exist!) at McAfee Avert Labs. You can see specific bug fixes at pages like this:
http://krbdev.mit.edu/rt/NoAuth/krb5-1.5/fixed-1.5.1.html
Ralph wrote:Yes apparently so as it seems many are accepting the lack of performance and the play with it until it works as being part of Apple's new human interface guidelines. I have used Macs way too long and have glommed through too much of the code to believe that this is "normal".
