Tom Krowka
Object/layer change
How can I change multiple objects that are on different layers to one common layer. Anything in a selection box or marquee will only do one entity at a time , it appears.
I'd like to change everything in a selection set at once. Is there any way to do this?
Thanks
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
Link
Hey Tom
This topic is actually covered further down the 'Working in ArchiCAD' page!
http://archicad-talk.graphisoft.com/viewtopic.php?t=2646
A search may prove to be quicker for you!
Link.
Ben Odonnell
Tom.
If you mark your objects on you floor plan, then click on the hammer icon next to you layers in the info box, you can then choose which ever layer you want your objects to reside on.
EDIT: If you want to include walls etc, make sure you use the arrow tool.
HTH.
Cheers.
Ben
Ben O'Donnell
