Offscreen dialog boxes
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2018-07-29 11:02 AM
‎2018-07-29
11:02 AM
Some dialog boxes were set to be opened on the external monitor, and when i only use my main display (laptop) those dialog boxes seems to be still on the external monitor (offscreen) so i can't do anything except pressing escape to cancel whatever i was about to do.
Usually i just plug the monitor back in, but i'm currently out right now and i don't have any access to external monitor at the moment, any suggestion?
16 REPLIES 16
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-15 02:50 AM
‎2019-02-15
02:50 AM
had same problem a while ago......i think on a mac it your display settings.....?
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
BRITISH COLUMBIA
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-03-25 12:11 PM
‎2019-03-25
12:11 PM
this happens to me ALL THE TIME !!
using windows,
If i close my laptop, THEN unlplug my external displays, AC won't reset the dialog box locations to the single laptop screen when I open later. This is EXTREMELY frustrating.
applying a standard scheme does nothing,
basically for now, make sure you unplug your monitors first, before closing a file
using windows,
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-07 06:15 PM
‎2020-04-07
06:15 PM
This is a serious issue.
I'm currently without external monitor, and every palette opens there. Thanks for nothing, Archicad!
Applying another enivironment does not help.
Please do some sanity checks here, before opening palettes, GS!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-10 02:43 PM
‎2020-04-10
02:43 PM
Well, I think I found a workaround:
It utilizes the fact you can export the workspace and the resulting file being a XML.
You'll have to edit the "Rect" values inside the "SizeableDockData" node.
Read more about it here.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-11 06:59 AM
‎2020-04-11
06:59 AM
The only solution i found was to draw all the later missing dialogboxes on the second monitor (bigger desktop-screen) back to the upper left in Archicad, before switching off the second monitor, before returning to a singlescreen-configuration. Expecially the Pet-Pals ar a mess..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-11 11:13 AM
‎2020-04-11
11:13 AM
Hmooslechner wrote:Servus Heimo,
well, the other solution is to edit the workspace scheme XML, as I linked above.
It's also the only solution btw that's viable when there is no other monitor around – a difficulty I faced.
Also it helps to keep two seperate workspace schemes: one, when connected to another display, and one when on a single monitor.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-13 03:08 PM
‎2020-04-13
03:08 PM
Hi All,
Thank you for sharing the issue and I am truly sorry about the experience!
This is a known problem to us. It seems like this is partly an ARCHICAD issue, as well as a Windows issue, as I haven't come across similar reports from macOS users. If you have this issue on macOS, please let me know! I haven't got a chance to test this yet.
I must say, this experience is a very painful one for me as well. Especially during these days, when working from home is a must and I use Remote Desktop every day, it is not easy when everything is set up perfectly on that 4K screen now being downscaled and messed up to my FullHD laptop screen!
This issue can be fixed by having different Work Environment setups. We have recorded a wish in our system already. Unfortunately, this is not something that is easy to change, due to the nature of ARCHICAD's user interface and how Windows behaves. I hope that we will find a solution for this soon, as I can see how annoying it can be when you have a deadline to meet and cannot find where certain palette is hiding!
Thank you very much for raising the issue! I am truly sorry for the inconvenience that this one is causing!
Have a great day, and enjoy the rest of Easter Monday for those who are celebrating it!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
