One Building-Different floor elevations
Hello everybody. Here I am after attending ACU West.
I returned home with good and bad news.
The good news are that I find out I know a lot about ArchiCAD.
The bad news is that I hardly know anything.
For example, I returned to the office to find out this building that needs to be split in three separate sections, each with the first floor elevation two (2') feet higher than the adjacent one while the relationship of the upper floors remains the same in each section.
So, here is the question: Do I assign first floor to elev 0'-0"; 2nd floor to elev 2'-0" and 3rd floor to elev 4'-0" or, is it better to ignore the model, unlink the elevations and "slide" each section up or down to show correctly.
The sections of the building can be managed with modules, however, modules do not relate to a floor level like library part which can be placed 2'; or 4' above a given floor level.
Please send me your comments/ideas how to document this building while preserving the 3D Model.
Conrado
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
Ok !
Ignore my post. I was mistaken. Modules can be placed a given distance above or below any given floor elevation.
Conrado
TomWaltz
You can also draw your floor slabs first, then use Gravity to snap to the proper floor level.
REALLY nice on those splt-level homes. Also useful to snap to a site mesh or a sloping roof.
Tom Waltz
