One line, multiple stories
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-03-24 06:26 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 06:31 PM
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 06:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 09:17 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 10:33 PM
The module can then be placed on any story, in the same file or other file (always without changing the origin when placing --and if you suspect somebody screwed up and moved the module, you just delete it and place a new instance). It is great for multi-file projects too, and also when you want to try out a design variation in some other temporary file.
Normally I publish the module from the working site file, the ground story being the only story where the module-generating elements reside (all the other instances are brought in module). Just to make sure I lock the elements (not the layers, that is), so that there is little chance that I can modify those inadvertently.
'Skip nested' should always be checked for these modules.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 10:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 11:20 PM
!! 2D Script HOTSPOT2 0, 0 HOTSPOT2 A, 0 HOTSPOT2 A/2, 0 !! midpoint if you like LINE2 0, 0, A, 0 !! if you want the line's 'edge' selectable HOTLINE2 0, 0, A, 0Show it on all stories.
(For a lot of geometry the module solution is great.)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-24 11:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-26 02:49 AM
James wrote:Yup. And you can use polylines, fills, arcs, stretch and trim, etc. And you keep single-source, pretty much live (placed modules update every time somebody hits 'save'), full control of the project geometry in multi-story, multi-file, multi-user projects, with or without Teamwork.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-26 04:02 AM
Ian C
