Opacity levels with fills
Just a quick question for you guys that Im trying to solve.
Is it possible to change the opacity of the 'polygon fill/hatch' tool when shading floor plans and sections etc ?
Thanks
3 REPLIES 3
Yes...but not via an opacity setting as in a page layout program. Instead, use a clear background and different pen widths for the linework of the fill.
For example, instead of one white pen, I have a set of white pens of increasing weights (ditto other pens - as is done by many others here). I use the 25% fill with white dots to mask stuff...using fatter and fatter pens to increase the amount of mask ... so thin pens are pretty transparent, thicker get pretty opaque. Same thing can be done with any color of course...and with variations of the 25% (or other) fills to give different densities.
HTH,
Karl
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
ABRHAM FANTU
There should be an opacity level setting for each fill templates.AC should work on graphics override settings.
The 'Empty' and 'Solid' fills can be duplicated and any opacity set for them.
They must be placed with a transparent background pen.
If you want an actual hatch as well, unfortunately you have to overlay a second hatch (vectorial or symbolic) fill also with a transparent background.
The original post was from 18 years ago.
I don't think we had the opacity fill option back then back then.
