Open Elevation view in 3D?
So I'm trying to render an elevation in 3D but I can't seem to open the elevation in 3D itself. I've already looked at 'Look perpendicular to' and Parallel projections but these don't give me the view I want.
Basically, I want to open the elevation view (attached) in 3D, in the exact same view as the elevation, no difference at all - very serious!
The reason for doing this is because I want to render the elevation so it looks less 'solid colours', as right now they seem flat even though I have shading and tried different settings, even overlying them in Photoshop.
Thank You
dl.dropbox.com/u/1055166/Screen%20shot%202011-01-23%20at%2014.51.23.png
10 Replies 10
Use the orthagonal/isometric view in 3D, select side view and choose the direction desired. You will then need to section the building using the marquee tool or the cutting planes.
That works but I can only view one story - How can I use the marque and select 2 sorties? I've tried CMD + A on Home story and 1st story but I can view both at the same time?
Thank You
Eduardo Rolon
make sure you have the bold marquee.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
It's still only showing the home floor
Eduardo Rolon
Did you use the menu,
View -> Elements In 3D View -> Show Selection/Marquee?
AC29 US/INT -> AC08
Yep, I did that... still can only view the first floor
Eduardo Rolon
Check that you do not have Cut Planes Enabled.
Same Menu choose 3D Cutting Planes…
If that does not work and all layers are turned on and there is "rogue" SEO I have no idea what might be wrong.
AC29 US/INT -> AC08
Here's a video if it helps:
Video
Eduardo Rolon
After drawing the marquee you do not have to "select all".
Just select "Show Selection in 3D".
AC29 US/INT -> AC08
