2014-06-29
02:05 PM
2023-05-25
05:57 PM
Rubia Torres
2014-06-29 02:45 PM
2014-06-30 12:40 AM
ejrolon wrote:I have opened an older version of Archicad (Archicad 10) on MacosX 10.9.3.
Start here with the converters and read the Migration guide for AC17.
https://www.graphisoft.com/downloads/fileconverter.html
I would try to use the converter to update to the earliest version that AC17 can use, then use 17 to bring it forward.
2014-06-30 03:15 AM
2014-06-30 03:31 PM
Jaime wrote:You don't need a G4, just a Mac that can run OSX10.6, which has Rosetta, which can run AC7. See this thread for partitioning a hard drive to run 2 operating systems: Mac mini won't open archicad.
So, it seems that the only solution is to run Archicad 7 on an older Macintosh, maybe a G4.
2014-07-07 12:19 PM
2014-07-07 02:52 PM
Dan wrote:Yes, because CodeMeter came out with AC13.
Most interesting point to note is that "3. Codemeter dongles will not install 8.0 or earlier versions".
2014-07-07 03:24 PM
2014-07-07 03:38 PM
Dan wrote:No, I didn't take it that way.
Hi laszlonagy,
Not that you're suggesting I am, but just to just say I wasn't necessarily complaining regarding the dongle (I hope it didn't read like that?). I totally understand that sometimes things just need to move on and technology can't be infinitely backwards compatible.
Anyway as we know from below/above, the file converter page looks like it has everything you need to get those dusty files open🙂
