Opening old ple files.
I have a lot of old projects in the ple format of yore. Any chance you could add ability to open those files? I would like to play around with some of my old school project. Maybe print some of them.
5 REPLIES 5
Eduardo Rolon
Nope. Even the current AC Edu cannot open them if I remember correctly.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
I understand that. It's more of a request to Graphisoft.
Probably best to contact your local distributor directly to see if there is anything they can do for you.
If You had version 9 EDU handy... You could do the job - AFIR ver 10 opened ver 9 edu files - but the extension had to be changed.
Best Regards,
Piotr
You mean that the regular version of AC10 could open v9 edu files?
