Override Cut Fill
When you activate the Override Cut Fill in Override Fill Display, which pen number is it actually using?
3 Replies 3
NCornia
The pen is determined by the Fill Pen in the element's Floor Plan and Section settings. For instance, under typical circumstances, in the Wall tool you would set the Cut Fill Pen in the Wall Settings/Floor Plan and Section/Cut Surfaces.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Nicholas sorry if I am misunderstanding your post
In order for the grey to appear as black fill, I need find what pen number is being used for that elements fill, then change that pen number in the pen sets right?
NCornia
Not in the pen sets, change the Fill Pen in the element's settings under the Floor Plan and Section Panel.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
