alemanda
PBC + floor plan cut plane heigh - floor plan representation
Hi to all.
I have a problem.
I have two walls, A and B
A is made of building material with strength 500
B is made of building material with strength 250
A is tall 1.00m
B is tall 2.00
Floor plan cut plane is at 1.4m
Both of them are in projected mode, all relavant stories
Both walls are placed on the same.
I expect to see wall B represented entirely and not interrupted at the intersection with A.
What do I miss?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
12 Replies 12
Is the junction order for both walls the same.
I am seeing what you would expect unless I play with the junction order.
alemanda
Yes.
Junction order is the same
AC27 latest hotfix
Win 11 Pro 64bit
OK I am out of ideas.
I am seeing exactly what you want if I follow your description (or similar to it anyway).
And with the cutplane lower.
alemanda
I'm in AC 19, latest hotfix.
I'll double check.
The file I'm working on comes from AC 18.
AC27 latest hotfix
Win 11 Pro 64bit
alemanda
I'm doing some tests with a new file, AC 19 ITA 4013, and something strange happens.
In order to see the correct representation the weaker building material should be higher than 440.
If it is weaker than 440 a uncorrect representation occurs.
AC27 latest hotfix
Win 11 Pro 64bit
You are quite right.
The same is happening for me with the break point being 435.
435 and above and it is fine.
Below 435 and it is wrong.
Barry
alemanda
Is it the normal and wanted behavior?
Or is it a bug?
AC27 latest hotfix
Win 11 Pro 64bit
I would say it is a bug.
