Learn more
PROBLEM WITH WALLS
Hello everyone,
i have a problem with my walls in my model. I am just learning archicad so i dont know how to solve this, hope somebody can help. My walls are attaching to my outer wall so i can see them on the outside. You can see what i mean on the photo.
Thanks for your help
5 Replies 5
Hello Vladimira,
I invite you to check the height of the shear walls which appear to be different from the height of the exterior walls. Or it is possible you have many walls from different levels at the same place into your BIM model.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
thank you for your advice, yes i have different height level. Our teacher at school told us to do the exterior walls lower and on top of that we should use arming with concrete and ceiling in your country it is called wreath. so those walls that are in interior are higher than those exterior walls. 😕
Guru
Check the your Building Material Strengths of your interior vs exterior walls?
Steve Jepson
Layer Intersect Numbers
It is definitely a building material strength issue.
Stronger BMs will cut away weaker ones.
Also this setting may help.
