Pan short cut key
Llian
I was following the chapter 1 collaboration and having problem getting the pan tool with shift key??? am i missing something ??
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
5 REPLIES 5
It is normally the middle mouse button that activates Panning.
Llian
thanks.....and your tutorials are great and admire your continuity from 4.5 to current. i started 4.0 in 1994 until 7.0 in 2004 but move on [not my choice] to autocad and revit .
Llian
i'm using the apply mouse and the dot is zoom ..so i just have to click on the icon bleow for the hand to pan..but i thought there is a shortcut key to use.
If you go to the Work Environment Dialog, there is a Keyboard Shortcuts page. Here you can find all the commands in ArchiCAD (including Pan) and you can assign a shortcut to any of them.
So you can use your keyboard to activate the Pan command.
Llian
thanks...i did it!
