2004-03-06 02:18 AM
2008-01-24 10:13 AM
2008-01-24 11:38 AM
NOELDESIGNS wrote:This is because you are using ArchiCAD 8.1. The cores did not join properly then, but they do now.
While AC does join walls properly, that does not always translate into having the core composites join properly, as you can see in the attached image.
Here is where the problem is most evidant. First, the drawing without any adjustment just isn't technically correct. The walls have to join properly, but so do the various composite layers, especially the core. In the image provided, the walls do join properly, but not the core composite.
2008-01-24 01:17 PM
