a month ago
Is there a way to get a perforated metal sheet modeled in AC without creating a thousand operators cutting holes through a surface? There's a perforated surface within AC that looks great, but it does not have actual perforations through it, its just a fill (see image below).
Thanks,
Phil
Operating system used: Mac Intel-based tahoe 26.5.2
a month ago
You have listed your two options.
Model the holes, which is not a good idea in large areas or complex shapes as you show in your image.
Or use a surface material that has the alpha channel hole built in.
If the surface material does not already have it, you can add a hatch pattern (fill) to show the holes in elevation (3D).
a month ago - last edited a month ago
If your image is of your "perforated surface within AC", it would appear that the alpha channel is turned off.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
You also need to have transparency turned on in the 3D styles and elevation settings if you want to see through the surface 'holes'.
4 weeks ago
I am using the "built in" perforated surface. None of these solutions seem to do the trick however.
Ido not understand how to add a hatch pattern (fill) to show the holes in elevation (3D) however. Where is that hatch pattern added?
4 weeks ago
You add the fill in the surface settings.
You will need to create a custom fill for the dot pattern as I don't think there is a default one that will match.
This is one I have for a chain link fence.
Looks like this in 3D with transparency on.
With textures turned off and hatching turned on (I don't have a hatch pattern for the perforated dots).
4 weeks ago - last edited 4 weeks ago
Can you take a screenshot of the settings dialogue of this "built in perforated surface"? What is it called?
With a fill, you will not get actual holes in Elevation. I think the alpha channel just makes voids filled with your surface colour...
4 weeks ago
I duplicated the 'circles 1' fill and changed the pattern size.
4 weeks ago
No, you won't get the holes in elevation, even with textures turned on.
That is why I suggested adding the hatch pattern.
4 weeks ago
Ah, so it just ignores the alpha. I have not tried it since it was first released since the documents produced were unusable...
