Perforated Wall
Can anyone tell me how to make perforated wall in archicad ...please or provide me any tutorial link please
Post has been moved.
Please look at the section descriptions to determine the correct place to post.
You could use empty window openings.
Or you could use beams that have a stronger building material strength than the wall (so they cut the wall automatically).
Then hide the beams on a layer that you can turn off.
Lingwisyer
Guru
You can use the multiply function to duplicate the beams into even spacings.
Ling.
