Please tell me how to make a ramp like this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-12-01 10:53 PM - edited 2023-12-02 05:38 AM
I can't make the connection part accurately. ^^
The problem is that it is difficult to process the green line part.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-04 10:23 AM - edited 2023-12-04 10:23 AM
It shouldn't be all that hard.
Flat slab for the corner landing and inclined beams or roofs for the ramps.
You could probably even play around with the stair tool and create the ramp.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-02 05:47 PM
A beam with complex profile at correct inclination might work
AC26, iMac
User since V5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-02 08:37 PM
Is it possible for me not to do this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 01:03 AM
I would use a mesh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 04:47 AM - edited 2023-12-03 05:34 AM
Is the answer to make it a mesh or a morph?
Custom Ramp Modelling - YouTube
However, there are concerns about whether the thickness of the slab can be accurately determined.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 12:28 PM - edited 2023-12-03 12:31 PM
Try making it with roofs and use Intersect Single-plane Roofs.
If that doesn't solve it then you will need to place a flat transition where the roofs meet to turn the corner. That is the only way to eliminate the twist where the beams are meeting in your picture.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 01:34 PM - edited 2023-12-03 01:35 PM
Thank you for answer.
It seems a little off. ^^
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 05:19 PM - edited 2023-12-03 05:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 06:21 PM
Yes, either.
Another option is to use 2 Slabs.
Convert to Morph
select the vertical planes
move them up (or down) in 3D Window
But I think that per IBC Code that corner needs to be flat and ADA compatible so all these suggestions are moot.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-03 07:58 PM
You should also note that in @Eduardo Rolon image, there is a new line in the ramp (red). This tells you that the 4 points forming the slab are no longer on a single plane and the top face needs to be formed by two triangles. This could be a problem for your finishes.
