‎2005-09-26
11:54 AM
‎2023-05-25
06:01 PM
Rubia Torres
‎2005-09-26 09:03 PM
‎2005-09-26 10:36 PM
‎2005-09-27 08:13 AM
‎2005-09-28 02:12 PM
‎2005-09-28 04:12 PM
‎2005-09-29 09:11 AM
I also have problems when the wall has the same hatch with the slab (but the hatch is defined as a composite)Would it help you if you selected a different pen number on the wall's (or slab's - section pen then) contour? That eliminates the automatic "healing"
Does anyone know a solution to that?
I tried playing with intersection priority in layers, but had no luck at all.
‎2005-09-30 11:49 AM
oreopoulos wrote:Agreed it is not normal. You would not build it that way, would you? The slab has to end before it hits the wall, or the wall has to start above and stop below the slab.
Also if i intersect a slab with a wall, why shouldnt the wall be cut from the slab? I see the wall hatch IN the slab. Is this normal? (of course i can cut the wall but why this happens? This is not normal.
‎2005-09-30 03:09 PM
