Problem: Cleaning intersections in Section
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-09-26
11:54 AM
2023-05-25
06:01 PM
Rubia Torres
In the section i expected to see the slab cutting the wall in two and see the slab clear.
I dont see that. (the wall is a composite wall)
I see the wall hatch AND the slab hatch together at the intersection point.
I also have problems when the wall has the same hatch with the slab (but the hatch is defined as a composite)
Does anyone know a solution to that?
I tried playing with intersection priority in layers, but had no luck at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-26 09:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-26 10:36 PM
If the two hatches are the same they will merge as one material in section. One way around this is to make a copy of the fill pattern with a different name and assign that to either the slab or the wall. And if you want the wall to stop at the slab why not just make the wall the correct height to the underside of the slab, or if it has to be higher for some reason use SEO to subtract with upwards extrusion?
HTH
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-27 08:13 AM
BUT if the wall has the hatch from a composite (for example i make concrete walls of 25cm a composite structure) they merge but i dont see the outline.
Also if i intersect a slab with a wall, why shouldnt the wall be cut from the slab? I see the wall hatch IN the slab. Is this normal? (of course i can cut the wall but why this happens? This is not normal.
Also changing layer intersection number does not help (i put the slab in a higher priority layer but still have the same result)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-28 02:12 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-28 04:12 PM
If the slab has a higher priority it should cut the wall. Just as in a plan view.
If i have to seo everytime i add a slab.............
I guess i have to make a new wish!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-29 09:11 AM
I also have problems when the wall has the same hatch with the slab (but the hatch is defined as a composite)Would it help you if you selected a different pen number on the wall's (or slab's - section pen then) contour? That eliminates the automatic "healing"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-30 11:49 AM
oreopoulos wrote:Agreed it is not normal. You would not build it that way, would you? The slab has to end before it hits the wall, or the wall has to start above and stop below the slab.
Unless you want to SEO all the time, which you obviously don't, and should not do!
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-30 03:09 PM
I mean I have a 5m heigh story, and along designing, i decide to add to half the story a slab to make some extra room.
It not nice to have to cut all walls just to place a slab.
I know it not build that way, but designing is very different from building cause i have to try different setups all the time. So i need flexibility.
How do beams cut walls. ?
If i draw i wall and then put a beam on top, the wall is cut.
This is normal. This is how it should be. Because when i design i dont know where i beam would go. When i am building i know.
So the approach draw as you build is not a holly script.
I should have flexibility.
