Structural grid
Structural grid? Is it possible to see structural grid in section view?
Thanks
3 Replies 3
Hi Gorans
Yes, but you will have to purchase an add-on from CadImage called Object Tools Pack. You can have a look at the information here http://www.cadimagetools.com/home.php?page=products.
I just recently purchased it for this reason. There are a few little things that I thought could be improved which I have notified them of, but overall it does what it is supposed to. It trims objects as well but I have not used that part of the tool yet.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
Just copy from floor plan to section/elevation window and it goes to the coerect location.
Joseph
Djordje
Joseph
Well, not exactly ...
For the grids that are vertical and for the views looking straight "up" or "down" it is a simple copy/paste/move to position for the ones looking up, mirror around the origin for the ones lokking down.
For the views that are looking to the shorter edges of the screen, copy/paste/rotate/move is in order.
I do this often ... so do get yourself the Cadimage tool!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
